Get economical power today with the Neo Eco 620C, Antec's high-efficiency power supply solution. Featuring 80 PLUS certification, a quiet double ball bearing 120mm fan, and universal input with Active Power Factor Correction (Active PFC), the Neo Eco 620C gives you a cooler, quieter system all powered by 620 watts of continuous power.
- Antec Neo Eco 620C - power supply - 620 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V
- 80 PLUS Certification
- 80 PLUS Bronze
- 2 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Power Capacity
- 620 Watt
- Output Current
- +5V - 24 A , +3.3V - 24 A , +12V - 48 A , -12V - 0.8 A , +5VSB - 2.5 A
- Output connectors
- 6 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Margin
- + 10% / - 10%
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Power Capacity
- 620 Watt
- Output Current
- Efficiency
- 87%
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Thermal monitoring, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, dual ball bearing cooling fan
- UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, GOST-R
- Limited warranty - parts and labour - 3 years
- 0 °C
- 50 °C
- 15 cm
- 14 cm
- 8.6 cm
- 2 kg
