The 3X Strength Spray is an Antec Advance Cleaning Solution created to keep your electronic devices flawless and functional. 3X Strength Spray contains a unique non-drip formula that adheres to your device's screen, allowing for quick and easy cleaning, and is anti-bacterial to keep your device germ-free. The included microfiber cloth efficiently dries your screen without any smudges or streak marks and gives it that extra shine. Protect your investment with Antec Advance Cleaning Solutions: the best solution for a clean screen!
Unique non-drip formula
Adheres to screen to prevent damage. -
Anti-bacterial
Fingerprint resistant: maximizes your screen's display. -
Alcohol and ammonia-free
Designed specifically for electronically sensitive devices.
- Antec 3X Strength Spray 240 mL + 60 mL Home & Travel Pack - cleaning kit
- Product Type
- Cleaning kit
- Package Content
- MicroFibre cloth, 60 ml cleaning spray, 240 ml cleaning spray
- Product Type
- Cleaning kit
- Package Content
