Antec's High Current Pro Platinum series is the pinnacle of power supplies. High Current Pro Platinum is fully modular with a revolutionary 20 + 8-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS PLATINUM and ErP Lot 6: 2013 certified, operating up to 94% efficient, you can reduce your electricity bill by up to 25% when compared to many other power supplies. HCP Platinum's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. The HCP-1000 Platinum embodies everything a power supply can accomplish today.
135 mm DBB silence
Whisper-quiet high-quality double ball bearing fan with long lifetime. -
Thermal manager
An advanced low voltage fan control for optimal heat and noise management. -
High current rails
4 high current +12 V rails with high load capabilities ensure maximum CPU and GPU compatibility. -
All Japanese heavy-duty caps
All high-performance Japanese capacitors ensure tightest DC stability and regulation. -
PhaseWave design
A server-class full-bridge LLC design with a synchronous rectification based on a DC-DC topology. -
Stealth wires
All wires darkened for minimal visibility in chassis.
- Antec High Current Pro HCP-1000 Platinum - power supply - 1000 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.32/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Platinum
- 2.2 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Power Capacity
- 1000 Watt
- Output Current
- +5V - 25 A / 0 A , +3.3V - 25 A / 0 A , +12V1 - 40 A / 0 A , +12V2 - 40 A / 0 A , +12V3 - 40 A / 0 A , +12V4 - 40 A / 0 A , -12V - 0.5 A / 0 A , +5VSB - 3 A / 0 A
- Output connectors
- 1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 8 pin EPS12V , 6 x 8 pin PCI Express power with detachable 2 pin section , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 9 x 7 pin Serial ATA
- Cooling System
- 135 mm fan
- 15 cm x 19 cm x 8.6 cm
- 7 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Margin
- + 10% / - 10%
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Power Capacity
- 1000 Watt
- Output Current
- 80 PLUS Platinum
- Cooling System
- 135 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, cable management, short-circuit protection, dual ball bearing cooling fan, CrossFireX ready
- UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, KCC
- Limited warranty - parts and labour - 7 years
- 15 cm
- 19 cm
- 8.6 cm
- 2.2 kg
