With the AG Neovo SC-17P, security centers can keep an eye on budgets without losing sight of performance. Digital and analog video inputs, including looping BNC I/O, minimize installation cost. Auto detection, settings key lock and auto settings adjustment reduce maintenance hassle. Quick signal-switching and rapid response time improve surveillance efficiency, while built-in speakers provide an additional level of security. All this and more make the SC-17P the perfect value display choice for any security environment.
- Neovo SC-17P - LED monitor - 17"
- LED-backlit LCD monitor - 17"
- Energy Class
- Class B
- Native Resolution
- 1280 x 1024
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 3 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, S-Video, composite video
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50 - 60 Hz)
- 37.2 cm x 18.4 cm x 38.52 cm
- 2.9 kg
- VESA EDID, CB, FCC, RoHS, WEEE, GOST-R, REACH
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 17"
- Native Resolution
- 1280 x 1024
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- 3D comb filter, Anti-Burn-in technology, 3D Noise Reduction, 3D Deinterlace
- 2.9 kg
TV Tuner
- Analogue Video Format
- NTSC, PAL
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- Audio line-in , Audio line-out , VGA , HDMI , Composite video output , Composite video , S-video
Mechanical
- Tilt
- Tilt Angle
- -2/+20
- VESA interface support
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x audio cable
- Input Voltage
- Power Consumption (Typical)
- 18 Watt
- 0 °C
- 40 °C
- 10 - 95%
