Acer V6 Series V246HL 24"  LED Full HD VGA DVI 3 year Warranty Monitor
Quicklinx: 8NTDWS00 Mfr#: UM.FV6EE.005
This stunning V246HL has some great features including DVI and replaces our bestselling low end 24" K series monitor. The V series is the next step up in terms of build quality within the Acer range and as such it carries a standard 3 year warranty for addtional peace of mind.
Main Features
  • Screen Size: 61 cm (24")
  • Screen Mode: Full HD
  • Response Time: 5 ms
  • Aspect Ratio: 16:9
  • Horizontal Viewing Angle: 170°
  • Vertical Viewing Angle: 160°
  • Adjustable Display Angle: Yes
  • Backlight Technology:LED
  • HDCP Supported: Yes
  • Maximum Resolution: 1920 x 1080
  • Standard Refresh Rate: 60 Hz
  • Colour Support: 16.7 Million Colours
  • Contrast Ratio: 100,000,000:1
  • Brightness: 250 cd/m²
  • Audio: Speakers
  • Interfaces/Ports: DVI VGA
  • Warranty: Standard 3 Years Warranty
  • Adaptable
    Explore the angle that's perfect for you with this Professional Series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Ergonomic design provides handsome style on your desk - or off: This monitor is wall mountable, giving you clear views with more room.
  • Convincing
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional Series monitors. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Prepared
    Collaborating with others is faster and more productive when you have plenty of ports available. Professional Series monitors allow you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA, DVI, HDMI, USB and even DisplayPort connectivity options.
  • Green focus
    Professional Series monitors are mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources. Acer also uses recyclable packaging to further reduce ecological impact.
Acer V246HLbmd - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Internal
Voltage
AC 120/230 V
56.7 cm x 20.68 cm x 42.22 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
170
160
LED backlight
HDCP
3.9 kg
Audio
Speakers - stereo - internal
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP)
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
Power Supply
Internal
Input Voltage
AC 120/230 V
23 W
Power Consumption (Typical)
20.9 Watt
Power Consumption Stand by
0.45 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Accessories (5)
8NTD StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
8NTD StarTech.com Articulating Monitor Arm In Stock £132.69
8NTD StarTech.com Dual Monitor Stand In Stock £91.00
8NTD StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
8NTD StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
Other bundles (1)
8NTD C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
