Acer V246HL 24" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: BQRQWS00 Mfr#: UM.FV6EE.026
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
  • Designed to adapt
    V6 Series monitors let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. These monitors are also wall-mountable, giving you clear views with more room.
  • Bright and clear
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Very connected
    Collaborating with others is faster and more productive when you have plenty of ports available. V6 Series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DisplayPort, VGA, DVI and HDMI ports.
  • Eco focus
    V6 Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
Acer V246HLbid - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
56.7 cm x 20.68 cm x 42.22 cm
3.9 kg
Germany
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Aspire 5; 5 Pro Series; Extensa 15; TravelMate P614-51-50AA, P614-51TG-52A6, TMP614-51-588N; TravelMate P2; P4; TravelMate Spin B3; P4; TravelMate X5; Veriton Essential ES2; Veriton Essential N VEN2580; Veriton N4; S4; X2; X4
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Mercury free, Acer eColor technology
56.7 cm x 20.68 cm x 42.22 cm - with stand
3.9 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
Germany
Power Supply
Internal
Input Voltage
23 W
Power Consumption (Typical)
20.9 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm - weight: 3.5 kg , With stand - width: 56.6 cm - depth: 20.68 cm - height: 42.22 cm - weight: 3.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Acer Aspire 5 A515-44, A515-44-R1N0, A515-44-R4XL, A515-44-R52A, A515-44-R567, A515-44-R5UZ, A515-44-R612, A515-44-R8HD, A515-45, A515-55-5135, A515-55-52NP, A515-55-79P6, A515-56-52S4, A515-56-576N, A515-56-77CG, A517-52-31EP, A517-52-326E, A517-52-33HD, A517-52-34BG, A517-52-34PS, A517-52-35SX, A517-52-54PS, A517-52-57RL, A517-52G, A517-52G-50MA, A517-52G-741M, A517-52G-74SF, A517-52G-77A9 , Acer Aspire 5 Pro Series A515-56, A517-52, A517-52G , Acer Extensa 15 EX215-22-R3GV, EX215-22-R6A7, EX215-31, EX215-52-38YV, EX215-52-397U, EX215-52-517E, EX215-53G, EX215-54 , Acer TravelMate P614-51-50AA, P614-51TG-52A6, TMP614-51-588N , Acer TravelMate P2 TMP214-41, TMP214-52-38MW, TMP214-52-53KG, TMP214-52-P9WY, TMP214-53, TMP214-53-32LS, TMP214-53-5543, TMP215-41, TMP215-52-33GE, TMP215-52-50HY, TMP215-52-53P4, TMP215-52-778D, TMP215-52-77R5, TMP215-53-36QE, TMP215-53-558S, TMP215-53-55UU, TMP215-53-70U8, TMP215-53-75AM , Acer TravelMate P4 TMP414-51-54EW, TMP414-51-561V, TMP414-51-73JS, TMP414-51-75QM , Acer TravelMate Spin B3 TMB311RA-31, TMB311RN-31-C09E, TMB311RN-31-C1C6, TMB311RNA-31 , Acer TravelMate Spin P4 TMP414RN-51-52PF, TMP414RN-51-552J, TMP414RN-51-77H9, TMP414RN-51-78UQ , Acer TravelMate X5 TMX514-51-560Q , Acer Veriton Essential ES2 VES2740G , Acer Veriton Essential N VEN2580 , Acer Veriton N4 VN4670GT, VN4680GT, VN4690G, VN4690GT , Acer Veriton S4 VS4670G , Acer Veriton X2 VX2665G, VX2670G , Acer Veriton X4 VX4230G
Accessories (5)
BQRQ StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
BQRQ StarTech.com Articulating Monitor Arm In Stock £132.69
BQRQ StarTech.com Dual Monitor Stand In Stock £91.00
BQRQ StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
BQRQ StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
Other bundles (1)
BQRQ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
