Acer KA220HQ 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: BK5CWS00 Mfr#: UM.WX0EE.001
Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment. Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
  • Great visuals
    See clearly with a beautiful Full HD display. Opt for a vivid IPS panel with a 178° wide viewing angle or lightning-quick TN panel to suit your needs. A 1ms response time reduces ghosting and takes action-packed entertainment to a new level.
  • Optimized comfort
    Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare and Blue Light Filter Pro to remove harmful blue light without sacrificing color or brightness. Get a good view with convenient-5° to 15° tilt adjustment.
  • Smart design
    On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
Acer KA220HQ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
50.8 cm x 16.4 cm x 40.24 cm
Microsoft Certification
Compatible with Windows 7
MPR II
3-year warranty
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
50.8 cm x 16.4 cm x 40.24 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption (Typical)
19.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 16.4 cm - height: 40.24 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm
Limited warranty - 3 years
Accessories (5)
BK5C StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
BK5C StarTech.com Articulating Monitor Arm In Stock £132.69
BK5C StarTech.com Dual Monitor Stand In Stock £91.00
BK5C StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
BK5C StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
Other bundles (1)
BK5C C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
