Acer K222HQLBD 21.5" 1920x1080 5ms VGA DVI Black Monitor
IMPRESSIVE 100 MILLION:1 CONTRAST RATIO
Quicklinx: 9DJDWS00 Mfr#: UM.WW3EE.001
The eco-friendly K2 Series value line is a cost effective display solution for everyday PC use, offering ease-of-use without compromising image quality.
Impressive 100 million:1 contrast ratio
The ultra-high contrast ratio is achieved via Adaptive Contrast Management (ACM), ensuring crystal clear viewing.
Fast 5ms Panel Response Time
The quick response time yields immersive graphics and video display
Enjoy the latest HD digital media
K2 Series features Full HD 1080p resolution.
  • Product Description: Acer K222HQLbd 21.5" Widescreen Monitor
  • Screen Size: LED-backlit LCD monitor - 21.5"
  • Aspect Ratio: Widescreen - 16:9
  • Native Resolution: FullHD 1920 x 1080 at 60 Hz
  • Brightness: 200 cd/m²
  • Contrast Ratio: 100000000:1 (dynamic)
  • Response Time: 5 ms (grey-to-grey)
  • Colour Support: 16.7 Million Colours
  • Connectivity: DVI, VGA
  • Speakers: No
  • HDCP: Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
  • Height Adjustable: No
  • Vesa Mount: VESA 100 x 100
  • Warranty: 2 Year Warranty
  • Stunning performance
    You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to an Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
  • Comfortable views
    The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment.
  • Smart design
    Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from-5 to 25 degrees.
Acer K222HQL bd - LED monitor - Full HD (1080p) - 21.5"
Energy Class
Class F
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
50.8 cm x 20.7 cm x 39.1 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class F
29 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM), ComfyView
DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MPR II
Power Supply
Internal
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption (Typical)
18.1 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.1 cm , Without stand - width: 50.8 cm - depth: 30.5 cm - height: 5.2 cm
Sustainability Information
ENERGY STAR Certified
Accessories (5)
9DJD StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
9DJD StarTech.com Articulating Monitor Arm In Stock £132.69
9DJD StarTech.com Dual Monitor Stand In Stock £91.00
9DJD StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
9DJD StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
Other bundles (1)
9DJD C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
