Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
Wide viewing angle
With its wide viewing angle of 178°, this monitor di splays colors perfectly. You can view it from almost any an gle and not experience any gray-level inversion or color washout.
Acer Adaptive Contrast Management
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by frame, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
Acer EcoDisplay
As part of our commitment to sustainable operations and corporate social responsibility, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
- Panel: VA LED
- LED Backlight
- Resolution: 1920 x 1080 @ 60Hz
- Aspect Ratio: 16:9
- Brightness: 250 cd/m²
- Contrast ratio: 100M:1
- Response Time: 6ms
- H/V° CR 10:1: 178 / 178
- H/V° CR 5:1: 178 / 178
- Display Colours: 16.7M
- Pixel Pitch: 0.276mm
- Colour Gamut: 72%
- PPI: 92
- Frequency (H/V): 30-80Khz/55-75Hz
- Connectivity: VGA, DVI (w/HDCP), HDMI
- Tilt: -5° ~ 15°
- MTBF Hours @ 25°C: 30000
- OS Certification: Windows 8 Compliant
- Power Supply: External
- Consumption On mode: 40W
- Consumption Standby mode: 0.3W
- Energy Star Type: ES6.0
- Dimensions (WxHxD): 618 x 400 x 117mm
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment. -
Wide viewing angle
With its wide viewing angle of 178°, this monitor displays colors perfectly. You can view it from almost any angle and not experience any gray-level inversion or color washout. -
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by frame, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power. -
Acer EcoDisplay
As part of the commitment to sustainable operations and corporate social responsibility, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
- Acer G247HL - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 54.6 cm x 18.6 cm x 41.1 cm
- Microsoft Certification
- Compatible with Windows 7
- MPR II
- 2-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame
- Black
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- MPR II
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Sleep
- 0.45 Watt
- Dimensions & Weight Details
- With stand - width: 41.1 cm - depth: 18.6 cm - height: 54.6 cm , Without stand - width: 54.6 cm - depth: 3.8 cm - height: 32.9 cm
- Limited warranty - 2 years
