Product information
3Com OfficeConnect Wireless 11g Compact USB Adapter - network adapter Image for illustration only
Customer rating
3.5*
View reviews
3Com
Quicklinx: 3Q3HWS
Mfr#: 3CRUSB10075
For simple, reliable, high-speed wireless connections for both desktop and notebook users, choose the 3Com OfficeConnect Wireless 54 Mbps 11g Compact USB Adapter. Users can access network resources, the Internet, and e-mail at speeds up to 54 Mbps - ideal for multimedia or other high-bandwidth applications. The USB adapter works with the 3Com OfficeConnect Wireless 11abg and 11g access points and the OfficeConnect Wireless 11g Cable/DSL Routers to create a powerful, high-speed, wireless network in minutes for home and branch offices, remote sites, and classrooms.
To protect wireless connections, the USB adapter supports advanced WPA encryption as well as basic WEP encryption. It also supports the latest 802.1X authentication to help protect against unauthorized users. The sleek, compact USB adapter offers the flexibility and convenience of USB connections without sacrificing performance. The USB extension cable works with a variety of desktop and notebook designs. Wireless Card Manager creates profiles for mobile users that reflect specific wireless LAN settings for each place they travel: users just select the proper profile and they are configured for connection. Dynamic rate shifting automatically matches the best connection speed in response to changing traffic and environmental conditions.
Customer reviews Read all 5 customer reviews
Write a review for the 3Com OfficeConnect Wireless 11g Compact USB Adapter - network adapter here!
Ubuntu linux
Reviewed by . Review Posted 30/01/2008
Works perfectly in ubuntu linux 7.04 upwards.....
And had no prob with it on xp either
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Very Reliable
Reviewed by Nigel. Review Posted 01/12/2006
I have found this product pretty straightfoward to install and set up,signal strength has been excellent
and encryption set up and use no problem.
  • Overall 5*
  • Ease of use 5*
One of the best
Reviewed by Anonymous Review Posted 11/06/2006
This is one of the best adapters i've used. Driver install info was sparse in the instruction leaflet, but once it was up and running, it gave great results.
  • Overall 4*
  • Ease of use 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Network adapter
External
Interface (Bus) Type
Hi-Speed USB
3 cm x 8 cm x 1.3 cm
25 g
IEEE 802.11b, IEEE 802.11g
Data Transfer Rate
54 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x
Microsoft Windows 98SE/2000/ME/XP
3 years warranty
Network adapter
External
Hi-Speed USB
3 cm
8 cm
1.3 cm
25 g
Wireless
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
54 Mbps
Line Coding Format
CCK
Frequency Band
2.4 GHz
Max Range Indoors
100 m
Max Range Open Space
400 m
Status Indicators
Link activity, link OK
Aerial
Antenna
Internal integrated
1 x Hi-Speed USB - 4 PIN USB Type A
1 x USB cable ( external )
Encryption Algorithm
AES, 128-bit WEP, 256-bit WEP, 64-bit WEP, WPA, WPA2
CE, C-Tick, EN55022, ICES-003, EN55024, UL 60950, EN 300.328, EN 301.489.1, EN 301.489.17, RSS-210, FCC Part 15 C, EN 300.328-2
Software Included
Drivers & Utilities
Peripheral / Interface Devices
CD-ROM
3 years warranty
Service & Support Details
Limited warranty - 3 years
45 °C
5 - 90%
Quicklinx search
My Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
Need help or advice
Get contracts signed in minutes
Free trial offer
